Mustang Dyno?
Mustang Dyno?
I don't know if this is the correct spot for this or not, if not please redirect me!
Alright i have a rather noobish question, but i really don't know.
What exactly is a mustang dyno? There is a place near by my house with one and i'm not exactly sure what it is as a opposed to a reg. dyno!?!
Anyways thanks for the help
Thanks,
Seth.
Thanks,
Seth.
I think th emustang dyno will actually put force on teh car as opposed to the dynojet dyno will be free from any force put on the car. The dynojet always gives the car a higher number, but I think the mustang dyno is more acurate. I think that is the difference between the 2, but I am not sure.
There are likely plenty of threads in the Dyno section...
But a Mustang dyno is also called a load dyno or an eddy-current dyno. You can simulate real load conditions (such as driving up a hill at partial throttle, etc) with the eddy-current style dyno. A regular Dynojet (without the eddy current option - it is an option on newer units) just measures wide open throttle performance. That's great - if you drive at wide open throttle 100% of the time.
Given my druthers, I'd choose a Mustang dyno every time for tuning.
And peak dyno numbers mean NOTHING. It's all about driveability and maximizing area "under the curve" on the dyno chart.
from a more real world perspective, what most people are used to when they hear dyno is a dynojet chassis dyno, basically a big drum in the ground or mounted on a trailer that measures how fast you can accelerate it. In contrast a mustang dyno is a couple of boxes that you put to either side of the drive axles on the car and actualy bolt to the axles which can simulate loads and by doing that it knows how much force it's putting on the drivetrain and can tell you that.
Mustang dynos generally read lower then dynojets.
