BMN Switch Help
BMN Switch Help
When it talks about wiring into the cars brake lines which one is it? Also I have my system installed and everything seems to work except for 1st gear lockout. The light will light up @ 3000rpms, but only if the 1st gear lockout is disenguaged. Anyone know what I wired wrong? When I take the 1st gear lock out off the system works as designed? Thanks in advance for the help.
TTT for you...what light lights up at 3000? Activation light? Could it be that it wont light up in first gear lockout mode at 3000 until it senses an rpm drop?
Also...what does it need to be wired to the brake lines?? Are you saying brake lights?
383LQ4SS not too sure what you mean about sensing an RPM drop. As long as I'm out of 1st gear and into my window (3000-5900) the activation light should be on, correct?
Also I meant brake lights, not brake lines, thanks for the correction. I wrote the post as I was pissed about the n2o not working correctly.
Well..I dont know the specifics on the BMN...but usually 1st gear lock out means it wont activate nitrous in first gear. How does the little box know its in first gear??
It doesnt...what happens is you arm it....and when you go WOT nothinng happens...because your in first gear lockout mode..until you have an rpm drop of a certain amount...then nitrous will kick in. That simulates starting in first gear...going WOT...and then shifting to second gear. naturally after the shift rpm drops. The box senses that and will then begin normal operation.
Atleast thats my current understanding. I havent used one yet.
Not sure what the brake lights are for. Are you sure its not a transbrake?
I have the BMN window switch with first gear lockout. The way it works is you must rev the car to the cut off point that you have set on the window switch. Once you reach the cut off rpm and the revs drop the switch assumes you shifted to second gear and will then allow the solenoids to operate.
Well I am still somewhat puzzled about this window switch. Took the car out on the highway and when the 1st gear lockout was engaged I would get nothing @ WOT. However if I took the 1st gear lockout off the gas flowed under WOT. Anyone got any ideas, because I'm totally stumped. Thanks
Read this very carefully ...
Reworded ......
What that means is that when the first gear lockout is engaged, it's assuming you ALWAYS start from 1st gear. Once you make the 1-2 shift and the RPMs drop, the box sees the RPM drop and ASSUMES that's a shift, thus engaging the nitrous.
This would perfectly coincide with everything you've said you're having a problem with.
Flyer thanks for the respnse. So what you and appearantly everone else has stated is w/ the 1st gear lockout engaged the n2o will come on only after the window switch senses the rpm drop after the shift from 1st to 2nd? And if I wanted to say do a highway run on the gas the 1st gear lockout would have to be disengaged? Thanks for all the responses.
So...if you're on the highway with the 1st gear lockout engaged you can't just floor it and expect your nitrous to fire. You'll have to go through one shift cycle. Meaning, your in 4th (for example) and arm your system. You floor it and go past 6000 rpm (example again) and shift into 5th. This time when you reach you window switch lower limit the nitrous will fire.
In order to just arm the system and have it fire immediately (within your window) is to disable the first gear lockout.
