Do I need a shift kit?
Old 04-12-2006, 10:22 PM
SVT THIS's Avatar
Default Do I need a shift kit?
First off, what the hell does it do? If we don't technically shift-what does it do? Are these necessary to have when you are heavily modded?
Old 04-12-2006, 10:29 PM
xxrillixx's Avatar
Its supposed to be alot more agressive. Allowing the driver to control the gears better, faster... with a crisper shift. It allows you to choose a gear depending on your RPM's.
Im assuming that when your at a higher rpm and driving more agressive, it will allow you to hold that gear there versus upshifting and then having to downshift again to get back into the powerband.
Its also supposed to be more durable... so, instead of re-building the tranny, it would upgrade it.
Old 04-12-2006, 10:30 PM
Pontiacerator
RevGTO's Avatar
LS1Tech 20 Year Member
Search a little - there have several threads recently on this. https://ls1tech.com/forums/automatic-transmission/485634-shift-kits.html
Old 04-13-2006, 09:46 PM
SVT THIS's Avatar
Thanks for finding the link for me
