header fab advice needed
is there any certin order the primaries on a header should go into the collector. i relize that it would be ok in any order but is there a certin order that would be better.
Whatever works out best for your header design is what I would say, easy way to fab it up is with some foam tubing and coat hangers bent inside the tubing to route the primaries to your collector
Suspended Sponsor
As long as you are not building a Tri-Y design, it really makes no diffrence, I would worry about the length and diameter much more! I worked for a header manufacturer for a few years doing the R&D and I have seen this first hand.
-Bryan
-Bryan
Originally Posted by AKAFRED
i will be using 1 3/4" primaries as far as i can see the end primaries will be the same but the middle 2 might be shorter unless i can add some length some how.
