View Poll Results: Should I take the catback off?
Yes
10
47.62%
No
11
52.38%
Voters: 21. You may not vote on this poll
Can I simply cut off my catback
Old 04-16-2006, 10:36 PM
SVT THIS's Avatar
Default Can I simply cut off my catback
Ok, here's the deal. I have all the mods in my sig, just not installed yet. I have been doing some weight reduction and am wanting to get rid of my catback. I am going to add some Dynomax bullet mufflers to the end of my SLP LTs when I get them installed. I am going to the track on Saturday to get some premod times. I would like to get all my weight reduction done by then. Can I simply cut of my catback and drive it like that for a while on just the manifolds? I have a cutout installed right now and I imagine it wouldn't be any louder than it is now. How much low end torque would I lose doing this?
SVT THIS is offline
Old 04-16-2006, 10:39 PM
DocEwww's Avatar
Open Y pipe? Sure, I know a few ppl who did it for awhile.
Would I? Hell no...u already have a cutout...ur not gonna gain anything and its a very minimal amount of weight.
DocEwww is offline
Old 04-16-2006, 10:44 PM
spy2520's Avatar
well if you plan on not running a catback with the headers theres no reason not to start early although it wont help much if any.
spy2520 is offline
Old 04-17-2006, 12:14 AM
Strahley's Avatar
If you're gonna start cuttin the exhaust off that's a good time to go with duals
Strahley is offline
Old 04-17-2006, 12:21 AM
blkZ28spt's Avatar
Are you positive you can simply add bullets the headers?
Most header's collectors exit at a location and angle on the driver's side such that you cannot put a straight piece of pipe on them without hitting the underside of hte car. The location where the factory Y-pipe is crushed...take a look if you havn't considered this already.
You can simply cut your cat-back off. Doesn't mean you should, but that is your decision. Where are you thinking of cutting? I wouldn't cut it off too far up. I would go for removing the cat-back but retaining the Y-pipe.
blkZ28spt is offline
Old 04-17-2006, 10:53 AM
SVT THIS's Avatar
I may do that. I got an SLP ORY with the headers and may just put one bullet muffler there. It'd keep me from wasting the Y pipe and buying two bullets.
Those who said it won't make much difference...The catback weighs like 50lbs. That, with the front bumper supports is almost 100lbs. Every little bit adds up.
SVT THIS is offline
Old 04-17-2006, 11:35 AM
blkZ28spt's Avatar
Have you actually weighed the cat-back and bumper supports?
Old 04-17-2006, 02:32 PM
SVT THIS's Avatar
No but other members on here have. Read this thread
https://ls1tech.com/forums/drag-racing-tech/17319-weight-reduction-list.html
SVT THIS is offline
Old 04-17-2006, 02:34 PM
hashtagBMW
Speed Density's Avatar
Do it! The night i took mine off i ran a new personal best. Every bit DOES count.
Speed Density is offline
Old 04-17-2006, 03:51 PM
SVT THIS's Avatar
Did you just saw it off? I have the SLP CME tips and am going to leave them on, but am wanting to remove the rest.
Speed Density: Did you remove the Ypipe and catback? Or just the catback? How was the sound? To loud or did it sound like a cutout? Thanks
SVT THIS is offline
Old 04-17-2006, 05:26 PM
SiL3NtXWS6's Avatar
there is a nice weight difference with and without the catback.. i can feel it while i'm driving. I would definitely get rid the muffler..
i run no muffler/no cats on my 408 car and drive it on the street all the time.
SiL3NtXWS6 is offline
Old 04-17-2006, 07:33 PM
Order 66's Avatar
I understand the idea of weight reduction, but its not a smart thing to do.
Order 66 is offline
Old 04-17-2006, 09:49 PM
SVT THIS's Avatar
Order 66 why is it not a smart thing to do? I don't really understand your reasoning.
SVT THIS is offline
Old 04-17-2006, 10:04 PM
MrDude_1's Avatar
not a smart thing to do? for the track?! its fuggin genious.
a friend of mine has what i consider the IDEAL street/strip exhaust setup.
he has the STOCK catback, slightly modded, with a electric cutout.
the muffler actually does its job.. it keeps his car (somewhat) quiet.. good for not pissing off the neighbors or attracting the cops.
when attention is wanted, the cutout is loud, and sounds decent.
and the best part..... at the track, he has a 3bolt flange on the muffler... just unbolt the muffler, and poof! instant ~30+ lbs off the car.... people do alot more and give up features for that kind of weight loss.. flow of course still goes out the cutout.
track require a muffler? no prob! put the same 3bolt flange on a 7lb bullet muffler and swap from the stocker to it.
takes minimal work, and works great.
anyhoo back to the orignal poster.... your car will sound crappier with the catback off then just the cutout... the exhaust still works like a muffler to take out some of the blat and tinny highs.... but in anycase, you can do it.. and its not totally unbearable unless you have a huge stall or 4.10+ gears..
currently im also running an open Ypipe... not by choice, but my exhaust didnt clear my 9" rear, so i had to cut it.. im going to redo it soon.
MrDude_1 is offline
Old 04-18-2006, 09:17 AM
Coy
Coy's Avatar
AT LEAST run a muffler at the end of the ORY. It actually sounds good, and cuts a decent amount of weight.
Coy is offline
Ric
Ric's Avatar
If you're near north GA, then yeah, cut it off... I want it!
Ric is offline
Old 04-18-2006, 01:18 PM
dug
dug's Avatar
sux2bu did something similar. Says its not that loud
dug is offline
Old 04-18-2006, 01:24 PM
GuitsBoy's Avatar
open Y pipe is no problem, but taking it down to the manifolds is asking for trouble.
GuitsBoy is offline
Old 04-18-2006, 01:33 PM
dug
dug's Avatar
didnt undersatand what he meant
dug is offline
Old 04-18-2006, 01:39 PM
BIG BAD BLACKSS's Avatar
Im sure you can find better parts to sawzall off if you really feel the need.
BIG BAD BLACKSS is offline
