T-56 to TH400 VSS reluctor ring?
Old 04-18-2006, 01:03 PM
DanZ28's Avatar
Default T-56 to TH400 VSS reluctor ring?
Hoping someone can clarify for me. I have searched but found nothing definitive about this.
Rossler is building my TH400 but it sounds like they typically use the A4 reluctor ring. I want to use the T-56 reluctor right (I have a M6 now)?
I'm just trying to gather any info regarding the right part numbers to use so I can pass it on to them if they don't find it first. I don't want to do anything funky with the PCM or use the WSS off the ABS system to make it work.
Thanks
Dan
Old 04-19-2006, 12:13 PM
DanZ28's Avatar
TTT
No one has went from a T56 to TH400 and used the VSS?
Old 04-19-2006, 03:05 PM
Yank's Avatar
We make the special m-6 ring for the TH400 and have for 6 years now
it is priced at $24.00
but you will also need the special Yank built pick-up priced at $190.00
to make it work with M-6 PCM settings
mike@converter.cc
Old 04-19-2006, 04:09 PM
DanZ28's Avatar
Good to know. I think you guys may be the only ones with this.
Does that include the tail housing?
Dan
Old 04-20-2006, 07:39 AM
Yank's Avatar
It uses the stock housing
Quick Reply: T-56 to TH400 VSS reluctor ring?
