dropping a transmission
Old 04-20-2006, 12:28 PM
clayton02LS1's Avatar
Default dropping a transmission
Do I have to remove the motor and trans as one, or can I just drop the trans out? Is there a write up or a guide that i'm not seeing?
Old 04-20-2006, 01:24 PM
warp10's Avatar
I dropped mine directly. No motor mount removal or Y-Pipe removal.
Old 04-20-2006, 01:46 PM
chadtx01's Avatar
I've dropped the tranny a few times. First time, left the y pipe on and it was a pain in the ***. Next time, dropped the y pipe first and that made things alot easier. No need to pull the motor though.
http://www.installuniversity.com/ins...sity/index.htm
Go to the writeup for the clutch swap, it'll help out.
Old 04-20-2006, 04:29 PM
BriancWS6's Avatar
Remove Y pipe, remove trans brace, drive shaft, torque arm, disconnect wiring harness/connections, remove center console and shifter stick, remove tranny to bellhousing bolts, drop tranny. Drain the fluid first or it will pour out of the tailshaft and make a mess.
Old 04-20-2006, 04:30 PM
Dustin's Avatar
Originally Posted by BriancWS6
Remove Y pipe, remove trans brace, drive shaft, torque arm, disconnect wiring harness/connections, remove center console and shifter stick, remove tranny to bellhousing bolts, drop tranny. Drain the fluid first or it will pour out of the tailhousing and make a mess.
Exactly!
Quick Reply: dropping a transmission
