Front end creak
Front end creak
I have a 96 Trans am and whenever I turn the steering wheel either way I here a creeking sound from the front end. Either way I turn it its the same sound. It still drives straight just the noise. I was wondering if anyone had any insight to this before I have to jack it up and start looking for problems.
Does it do it 100% of the time, even after driving for a long time?
As the rubber parts start to dry out a little you can get some of this, but it should go away after a few miles. If it sticks around then you should probably get under there and take a look at everything in the front suspension, ball joints, strut mounts, sway mounts, etc.
