Moser 9" LT1 vs. LS1
Old 04-25-2006, 05:47 PM
silverTA2002's Avatar
Default Moser 9" LT1 vs. LS1
Will a Moser 9" setup for a 95 Trans Am bolt right into my 02 Trans Am?
If not, what will I have to buy to make it work, and how much $$?
Old 04-25-2006, 06:28 PM
SPEEDYws6's Avatar
You will have to get your backing plates pressed onto the axles.
Old 04-25-2006, 06:49 PM
sykotic's Avatar
Not much, if you have a press then nothing. Depending on how used the rear is you may want to get some new bearings & press rings just for fun, and possibly axle seals. Remove existing bearings, put on your abs rings(if needed), then backing plates, then bearings, then press ring. For the lt1 I believe there is a 1/8" shim between bearing and brake backing plates, make sure to leave this off if there is one. Other then that the housing etc should all me exactly the same because I think the only thing shipped differently for the LT1 and LS1 is that shim.
Old 04-25-2006, 06:58 PM
hotrod79's Avatar
Default axles
if your going with alot of hp u should think about what size axle to get 35 or 40 sline depending on what u get
Old 04-25-2006, 07:22 PM
I have maybe 400rwhp.
It already has either 31 or 35 spline axles.
Hopefully 31. (daily driver car)
Old 04-25-2006, 10:59 PM
Racer8102's Avatar
Should be a easy swap, real simple if you have deleated your abs.
Old 04-26-2006, 12:01 PM
I doubt it would have the ABS hookups.
What will I have to do to not use ABS?
Will it really affect my daily driving?
Will I still have ABS in the front, or does it disable everything?
