Quick Question? HELP!!!!
I bought a 94 Camaro Z28 CHEAP!!!! only 70xxx miles on it... It runs like it is not firing all cylenders.... Could it be the OPTI spark?? The car had a water leak also.. It was leaking water out of the thermastat housing and running down the back of the Water pump. On to the opti... Who knows how long it has been doing that... Could the opti act like that? ( like it not firing all cylenders) ... I have herd that when the opti is messed up it just straight up goes out.. Is that true??
Originally Posted by 2K2WS6TA
It can go out all at once, or the performance can degrade over time.
I'd fix the leak, then replace the opti, chances are that'll fix the problem
Remember water and optispark don't mix
