Textralia is here
Old 04-26-2006, 12:53 PM
silver02ws6's Avatar
Default Textralia is here
Got my clutch in today.
My new rear is going to go in this weekend. Im thinking about going ahead and installing the clutch along with it. Ive never done an install though so im curious as to wether or not i will be able to pull it off myself.
Old 04-26-2006, 03:05 PM
NHRATA01's Avatar
I say give it a shot. I had never done one myself either last summer, and undertook a Textralia install after toasting my Spec 3 at the track (welded it to the flywheel). It really wasn't too bad, went at my own pace and probably took about 12 hours. Removing the pilot bearing if you are changing it is a bit of a PITA. Its a good thing to learn how to do, especially if you have mods and race a good bit, since you can figure it probably won't be the last time you need to do the clutch. Also be sure to use red locktite on the pressure plate to flywheel bolts.
Old 04-26-2006, 03:19 PM
Ive got a whole new slave to install so i dont have to change anything out just put in the new parts.
Old 04-26-2006, 10:03 PM
Murdock's Avatar
The pilot bearing (NHRATA01's post) is in the end of the crank where the trans input shaft slides in. To replace it, you have to pull the old one out of the crank.
Old 04-26-2006, 10:53 PM
ok..................im very unimformed as i have never done a clutch install. I guess i will be purchasing a pilot bearing. Is this the only other thing i will need for the install or are there any other suggestions. I want to do this once and only once.
Old 04-27-2006, 06:39 AM
NHRATA01's Avatar
If you bought a Textralia they should have a pilot bearing with the kit - its in a small box.
To make life easy you'll want to pick up a small bearing puller. I think it was northern tools that has a small 2 jaw one (shouldn't be much, probalby <$20). I bought a 3 jaw one from Harbor frieght but the jaws were too big to fit in the bearing. Had to use only 2 of the 3 and grind both down a ton. It worked, but no too pretty.
Old 04-27-2006, 07:01 AM
ProjecT 9's Avatar
ya man the clutch install aint hard. just take your time and follow some instructions from installuniversity...
Jon
Old 04-27-2006, 11:25 AM
Camaroholic's Avatar
Make sure the threads are clean on them, and use loctite on the pressure plate bolts. Loctite blue at a minimum. DO NOT SKIP THE LOCTITE.
I would be very happy if I never saw another "my pressure plate bolts backed out on my Textralia clutch" thread, ever again.
Old 04-27-2006, 12:17 PM
Ive got $26 worth the red locktite just waiting to be used....LOL
I recieved my slave but no pilot bearing.
Old 04-27-2006, 01:09 PM
