Cam...Decided on my new grind!
Old 01-20-2003, 03:41 PM
DanZ28's Avatar
Default Cam...Decided on my new grind!
After some research and help from other's, I've decided on this grind: 230/227...601/581-111LSA +4.
I think this will be the answer for both N/A and juice, what do you all think?? <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Dan
Old 01-20-2003, 04:09 PM
11 Bravo's Avatar
Default Re: Cam...Decided on my new grind!
Wouldn't you want a regular split for nitrous?
Old 01-20-2003, 04:22 PM
DanZ28's Avatar
Technically yes, this is a compromise and should do well either way, most of my track runs will be N/A though...
Dan
Old 01-20-2003, 06:13 PM
ROB'S SS's Avatar
i have a very simular cam myself. 230/228, 591/588, 111+4*. its not a dyno cam as i only pulled 353 rwhp locked through 4.56 gears, but it pulls hard after about 4500-5000 and i have my shift points at 6800. the 25th is the first track date and ill post new times with it.
Old 01-20-2003, 06:34 PM
Onyx LS1's Avatar
You should go with a MTI X1, its specs are basically the same as those.
Old 01-21-2003, 11:30 AM
DanZ28's Avatar
Rob, those numbers sound pretty low for your set up, very strange.
Onyx LS1, I wanted something a little bigger than the X1 that will pull harder up top..
Dan
