help picking gears
Old 04-27-2006, 09:55 PM
skinbrain's Avatar
Default help picking gears
i need some help picking gears for stock 10 bolt with m6. can't decide between 3.73-3.90-4.10. car is pretty much daily driver, but makes about 20-25 passes a year. do you lose gas mileage with the 4.10s, on the highway? also wondering if a rear end cover girdle is worth the extra money? will it help the rear hold up to harder launches with drag radials? thanks for any advice
Old 04-28-2006, 12:44 PM
OctaneZ28's Avatar
While a TA Girdle does beef up the pumpkin a little, the rear end is still a weak 10-bolt.
4.10s are the most common choice for an M6 car, but keep in mind a numericly higher gear ratio will get worse gas mileage.
Old 04-28-2006, 01:52 PM
ohsofast's Avatar
You have to use 4.10. With that 6 gear you will hardly notice difference on the highway. Anything less in M6 is a waste of money. You should be asking 4.10 or 4.56 lol
Old 04-28-2006, 05:39 PM
hotrod79's Avatar
4.10s 0r 4.56 doesnt effect gas milage much
Old 04-28-2006, 05:57 PM
skinbrain's Avatar
thanks for the info. 4.10s going in soon.
Old 04-28-2006, 08:52 PM
mike2244's Avatar
with the 4.10 you will be at 1900 rpms at 70 mph in sixth gear. 4.10 is the way to go
Old 04-28-2006, 09:00 PM
skinbrain's Avatar
Thumbs up
is there much difference between the 3.90 and the 4.10s? if i,m at 1900 rpms at 70, will i be above 2000 rpms at 80mph in 6th gear? if i am will i lose alot of gas mileage? thanks for any help or info
