Some more PurEvl #'s,pretty much done for now
Did some final runs with the new Turbo.Here is a graph of 8lbs,12lbs and 15lbs.All the same timing and A/F at 11.5-1 (cutout open so dyno didn't read it right) No dyno,high # tuning.
Tried to go past 15lbs but it wouldn't.Either the controller won't or the inlet was just a major restriction.Didn't feel lucky enough to pull the inlet off and Mike didn't want to fix the car again
So these #'s are all 93 octain.I've been beating it for awhile on 15lbs with no problems at all. Car is tuned 2bar.
408 8.5-1 compression
AFR 225's
218 Cam
Edelbrock Carb intake
Custom fuel system with 2 Weldon A600's,75lb injectors
Custom single T88 Turbo setup with truck manifolds ect
M6
9" with 3.70's
And a bunch of other stuff but you get the idea.
Car will pass dyno emmisions no problem,idle's at 750rpm with no lope.
AFR 225's
218 Cam
M6
9" with 3.70's
Originally Posted by onfire
Nice numbers.
With the 2bar are you tuning the boost up and down now on the same tune?
Nice numbers.
