ford escape egr problem
Old 04-30-2006, 02:53 PM
natronathon's Avatar
Default ford escape egr problem
got a po401 today, insufficient egr flow. Does anyone know where the egr is on the ford escape 3.0 v6 model? Im guessing the valve is going bad, or it could be a bad sensor too... anyone know where the egr valve/sensor is located on the ford escape?
Thanks in advance for the info...
Old 05-06-2006, 06:01 PM
Marc 85Z28's Avatar
P0401 EGR insufficient DTC is caused by a faulty DPFE (Delta Pressure Feedback EGR) sensor, and will be covered free of charge for an additional 2yrs/24000 miles at your Ford dealer. If your are out of the extended coverage period, its a very simple replacement. It will be located near the throttle body, behind the intake. It should have one connector and 2 gray hoses attached. The replacement sensor will look different.
Quick Reply: ford escape egr problem
