slave cylinder/throwout bearing...
Old 04-30-2006, 09:08 PM
Yellowbrother's Avatar
Default slave cylinder/throwout bearing...
how do i remove the quick connect thingmajig on the slave??? i had to hacksaw that shiet so i can take off the slave...but i can't remove the whole thing...can anyone show me how???
Old 04-30-2006, 09:50 PM
mrhzk35404's Avatar
The plastic piece pushes in and unlocks the line.
Old 04-30-2006, 09:55 PM
so i just put the throwout bearing back on the round plastic slave cylinder and push it in??? and it should unlock the line??? or u talking bout the thing that protrude from the quick disconnect thingmajig??? i appreciate any help i can get...thanx...
Old 05-01-2006, 12:03 AM
P Mack's Avatar
No, not the throwout bearing. To unhook the quick disconnect you need to push the white plastic ring on the quick disconnect in (towards the slave cylinder) and it should pop apart.
Old 05-01-2006, 05:36 PM
hmmm...lemme take a pix and post it later tonite....i think i chopped off the piece ya'll talking bout...
Old 05-01-2006, 07:22 PM
NVR_SPDS's Avatar
Look at the braided line that runs to the slave. You see the connector? There is a little white piece of plastic with a flat edge on it. You push the line, and the white plastic piece in, and the hose will pop out, when you pull back on it.
