Engine set-up change
Old 04-30-2006, 11:56 PM
JoeSS's Avatar
Default Engine set-up change
Ok i have a built 347 forged bottom-end that has a 11.1 compression. I will be taking my heads and cam of the car because,I want to go forced induction.I am going to install a supercharger and want to run 10-14psi what can i do to reach a good set-up with out pulling my motor to swap pistons.
Old 05-01-2006, 05:34 AM
EPP
EPP's Avatar
Swapping on a set of LQ9 heads, such as a pair of Patriot's, will lower your compression ratio down enough to run 10 to 12 psi of boost, provided you have access to 93 octane fuel. Bob
