Is my Ram HD slipping(PLEASE HELP)?
I have a D&D performance T-56 with a fidenza flywheel and Ram HD clutch. I installed the MS3 and Stage 1 heads this weekend. Now my clutch is slipping, it starts slipping at 2800 rpms n when it gets to around 4500 or so it kinda grips. Wut could it be?
It is very possible the issue has to do with the flywheel finish. Fidanza does not grind their flywheels and the inserts are not flat, we have seen it time and time again. Also the slippery finish (not ground) will not properly seat the disc. I would bet this is most of the problem...
Mike
Mike
