NO Digital dual window switch
Old 05-01-2006, 11:02 PM
chris.shea's Avatar
Default NO Digital dual window switch
a few wiring questions before mine arrives and i install it.
1).this piece should be compatible with my fpss right?
2).*User configurable for rising or falling TPS signal
i hear you get a better signal through the falling pink wire is this true?
3).do they make plug and play pieces so i dont have to cut into my stock wiring for my tps signal and tach signal? im not a big fan of cutting into the stock stuff and was talking to a guy yesterday and he said he had a plug and play piece. maybe ill stop my his shop tomorrow and see but want to confirm this first.
4).anyone know what each color wire is at the tps?
-blue = rising
-pink = falling.....
i also got some wiring instructions that were posted before that are pretty close but dont tell me any answers for the questons above
http://img143.imageshack.us/img143/9...wswitch6xa.jpg
Old 05-01-2006, 11:13 PM
Closed ex-Sponsor Account
NXRICKY's Avatar
By the drawing the WOT will not be used by the Vette. 02 go with rising no problems there. 05-06 have the issues. FPSS just use enbetween the control grounding wires from your switch to the relay.
Ricky
Old 05-02-2006, 01:19 PM
chris.shea's Avatar
anyone have answers for ?'s 3 & 4?
Old 05-04-2006, 04:16 AM
chris.shea's Avatar
ok i edited the image to what mine looks like. FPS2 = fuel pressure safety switch. i also removed the orange cause im using single stage and didnt want to confuse anyone with the extra wire. i also removed the toggle ground as i didnt use the lite up toggle as the ones with the kit idont like and the ones i have are on/off(no light) there is also fuses between the battery-relay & battery-toggle switch.
does everything look alright? i truely hate wiring so if you see a problem let me know cause i dont trust my wiring work
Old 05-04-2006, 08:52 AM
NXRICKY's Avatar
looks good.
Ricky
Old 05-04-2006, 01:15 PM
chris.shea's Avatar
Originally Posted by NXRICKY
looks good.
Ricky
but will it work? i dont think the FPSS is in the right spot
if its right all i need to wire is the tach & TPS and program it. i still have to wait till the 11th for plug wires though
Old 05-04-2006, 03:20 PM
BMN
BMN's Avatar
It's in a plenty good spot. It is just closing or opening the low current line that is switched to ground via the FJO
