Victor Jr port matching
Ive seen few pics of the victor jr intake port matching the head intake ports, here is some of how mine lined up:
more here:
http://www.force-fed-fabrications.co.../AFR/pics.html
seems better then others Ive seen, I'll just port it down that 1/16th and slap it on the car, can't wait!
I have several other goodies already in the shortblock
more here:
Yes from the looks of it, the heads need to be ported to fit the intake, which is weird!
I hope some other people chime in on this it may just line up it was so close....
Tiago, I'm in the process of the same thing...move the intake around a little and you may find a "sweet" spot where you'll find the intake needing some grinding not the head. Best thing would be for you to install the heads "ink" the heads then install the intake. You'll see where your at then...Your not getting a correct reading just mounting the intake on the heads like you have it now. Be sure after the port matching you install the intake with a good light looking down each runner to line everything up. Without any kind of shoulder bold or thicker bolt that intake can move around quite a bit. Good luck with your project...looking killer!!
Originally Posted by DJ's99SS
Tiago, I'm in the process of the same thing...move the intake around a little and you may find a "sweet" spot where you'll find the intake needing some grinding not the head. Best thing would be for you to install the heads "ink" the intake then mount it. Your not getting a correct reading just mounting the intake on the heads like you have it now. Be sure after the port matching you install the intake with a good light looking down each runner to line everything up. Without any kind of shoulder bold or thicker bolt that intake can move around quite a bit. Good luck with your project...looking killer!!
yea I was thinking the same thing, it was so loose that it would probably line up just fine after it was on the car. how much overlap did you end up having on the intake to the heads after all?
Originally Posted by CP05GMC
Finally... looking nice.
I am going to show you the macro button on your camera though.
Cp
Cp
I need to learn that, I tried every setting I saw dammit
Your probably looking at close to 1/8" around each port. You don't have to get it perfect as far as intake matching the head but as you know you just don't want the head to be the obstruction. Leaving a little smaller intake before the intake port of the head won't make any real difference...just don't want it the other way around. We'll have to do some "playin" after we're both done...We'll go Supra hunting one eve.
Autobahn's shop is right around the corner for me
thanks,
Restricted User
Sweet post Tiago. I am looking at getting the same top end, but bolt it to my ETP Heads. I also heard a lot of ppl having to port the intake, but like you, I can see where the head needing to be opened up a little would create a wall, blocking smooth flow. Post up pics after you get it finished please. Thanks.
Charlie
Charlie
Originally Posted by xssive
Looks like you dont have the gaskets installed either. Those will raise the port floor of the manifold up a bit in relation to the head...
Here is a trace of the ports overlayed, you can clearly see the overlapped areas, the darker line is the heads, hte rectangular shaped lighter port is the intake, I dont' know if I should port this, looks like it is a hair from the gasket groove already.....
Edit: for clarification the ouside rectangle is the inside of the O ring groove already you can see the top and bottom of the ports are 100% matching .
Also the geometry might change a bit with the heads on the motor and torqued down. I wouldn't port it based on an off-engine mockup. The block is the master - the heads have to key off of it, then the manifold keys off the heads.
Jim
Jim
