Missing coil pack codes help
Old 05-04-2006, 11:36 AM
badazta99's Avatar
Default Missing coil pack codes help
I had the local parts house check the codes on my TA, found problem
with coils b,d,f,g...all 4 packs on one side couldn't go out at once could they.
What and how can I check to see what the issues are??
Help please this thing is driving me f'n nuts
Old 05-04-2006, 12:06 PM
618HAWK's Avatar
Cant see all 4 failing at once, Look for somthing common to them. Check you fuses under the hood. Should be a 15Amp mini-fuse. Might of had one coil go bad, which took out the fuse, wich killed all 4.
Take a look at the connector for that side. making sure all is clean and tight with no damaged pins or wires. All 4 packs use a common ground as well for both the control ground and supply ground.
Old 05-04-2006, 01:00 PM
horist's Avatar
also make sure the connection (they share a common connection in the center of the coil pack tray) is secure... pull it off and check for corrosion (I had some corrosion in mine and it caused one of them to fail... cleaned it up and has worked fine since)
