power with 96lb/hr injectors
I think I just maxxed out my racetronix 50's. Im at 602 RWHP and by 5200 rpm I start going lean and my injector cycle duty goes to like 102% by 6100 rpm it 120% . Im thinking Im maxing these bad boys out and need bigger ones. What do you guys think?
Originally Posted by smokinHawk
running the fuel calculators said their good for about 1200fwhp at 100% duty cycle.
I had to move from 96's to 160's when the boost went up and I didn't want to bump my base pressure any more.
BSFC is one "****" for figuring out what you can make with an injector, but start pushing the RPM and you lose that ability.
FWIW, you only have ~15ms to get in all your fuel at 8K RPM. I was seeing 12 to 13 ms pulsewidths with 160's at ~30psi on my old setup. Was I making near max power of those injectors? Nope, but I was fueling to keep my valves at a reasonable temperature ~10.3:1 give or take a tenth.
RPM MUST be considered when sizing you injectors
Originally Posted by y2khawk
At what RPM and base pressure is really the question.
good info about the rpm, dont think ill be spinning that high, just gonna try for 7k and hoping the 96's will get me to 1000rwhp, might install my 28's to do a little bit of work to, but mostly street duty.
