Bottle has nitrous in it BUT!
Old 05-07-2006, 08:44 AM
02Vortech's Avatar
Default Bottle has nitrous in it BUT!
okay so i made like 5 or 6 passes on the 100shot last night and then went to race a G35 coupe and there was no purge no nothing- went and checked the bottle everything was cool- close bottle up take line off then check to see if there is any nitrous- yes massive white cloud comes out- put line back on and turn bottle back on- still nothing...
anyone got any ideas? bottle was still @ 900psi
Old 05-07-2006, 09:39 AM
Turo's Avatar
The bottle could be runing low. The psi may be at 900 with the bottle closed, but as soon as you hit it (or purge), it may be dropping down quite a bit if its almost empty.
Also, sometimes purging doesn't have teh big white cloud. It can come out completely clear.
Old 05-07-2006, 10:01 AM
02Vortech's Avatar
well it was a full fill and i only got 5 or 6 runs in with a 100shot not even 1/4 mile runs just short sprints
Old 05-07-2006, 04:16 PM
7 Second Club / STF Veteran
68maro's Avatar
the only way to know is to weigh the bottle and see if anything is in it.
Old 05-07-2006, 04:19 PM
Moderator
thechef's Avatar
yup
Old 05-07-2006, 04:30 PM
shaZZam's Avatar
My N2O won't hit when the bottle has anywhere less than 3 pounds left in it. Just one of those things. There is probably nothing wrong with yours, just refill your bottle and spray on.
Old 05-07-2006, 05:01 PM
badass 2002 z28's Avatar
I've never gotten more than 5 full passes out of a 10lb bottle...all that's probably left in ur bottle is air
Old 05-07-2006, 08:43 PM
slowrollin93's Avatar
I run a 100 shot and get quite a few runs out of a full bottle, you said there was "no nothing" were the solenoids even opening? It might be a wiring problem check your fuses.
Old 05-07-2006, 08:49 PM
JustAnIlluzion's Avatar
nitrous filter could be clogged
Old 05-07-2006, 08:58 PM
Reject's Avatar
that's what i was going to recommend.
Old 05-07-2006, 10:30 PM
cartekls1's Avatar
might want to specify where to check the filter!
Old 05-07-2006, 11:59 PM
chris.shea's Avatar
unless you have an inline filter the only other filter is a screen on the inlet side of your nitrous noid.
Old 05-08-2006, 09:45 AM
02Vortech's Avatar
NO since i didnt see any nitrous come out of the purge i did not spray because i didnt want to run to rich. I meant "no nothing" bye how much was comming out of the purge- i think i have leak in my guage port of the bottle- so i took it out and reconnected it with PLENTY of silicone sealant
Old 05-08-2006, 05:24 PM
68maro's Avatar
i hope your kidding. use threadlocker only. or teflon paste. teflon tape and silicon sealant will break down and screw up everything.
