Head gaskets for boost?
I would like to hear opinons on the best way to seal the heads on the LS motors. I would like to hear what your expiriances have been with different brands and such. This would be for a higher end turbo application (14-16 psi.)
Thanks,
Mark
Thanks,
Mark
OK why?
Originally Posted by APD*98SS
Cometic head gaskets, all day long...
Mark
Originally Posted by fast240z
I have heard that quite a bit, however I have also heard Fel-pro. I have also heard you should O-ring the heads outside the fire ring. Please tell me why you believe what you believe.
Mark
Mark
everyone has his or her own horror story to tell, I had reciver groves in my heads done as you stated. I just had them cut and removed. I will be running a cometic gasket with no o-ring or reciver grooves.
Yes and people run 500-650 HP on stock GM LS1 crankshafts also. So go ahead and load a revolver with one bullet spin the cylinder, put it to your face and pull the trigger. What's the matter not a gambler? Then don't gamble with your 5K to 8K and up engine on what some people choose to do. If your that cheap not to spend the few bucks on some reassurance, then your not in it to win it anyway.
Originally Posted by JMBLOWNWS6
I havent heard of anyone breaking there stock crankshaft at 550 to 650 rwhp.
Originally Posted by TwnTrboCE
Haven't heard of anyone breaking one at 1000rwhp. I also run GM 6.0 MLS gaskets. At 28psi. Yes, I'm that cheap.
You Sir are an anomaly, congratulations on your status. However, I did not post my and I emphasize my opinion for scorn or sarcasm. Contact any reputable engine builder and they all recommend using quality parts. If you choose to take shortcuts or even envelope your own intuition into your project, I believe that is your opinion, and I still emphasize your opinion. I’m not one much for debate, simply do the math. In this twisted ideology from the original intent, head gaskets. First, Strength between a stock LS1 crankshaft and lets say a Lunati 4340 Forged steel crankshaft? Is there even a comparison? Second, the ability of a head gasket to do their job; Cometic versus stock GM Ls1 Head gaskets; Take a poll if you like.
In your signature you list an LS2 crankshaft. Well I’ll be darned. Forgive me but isn’t that thing FORGED??? Finally talk is cheap. No offense but I need to see some evidence of this 28psi 8.59 second fire breathing Demon you make reference to…
On the contrary, I think you did post your opinion and sarcasm. Why the reference to loading a gun and putting to your face?
On topic, who ha more money for R&D cometic or GM? HHHMMMMM just a guess that GM spends more on head gasket testing every year than cometic is worth in its entirety. I prefer the gm MLS gasket as well, and infact see tecnology that GM first put in the mls gasket copied in the cometic. Both are good, one costs more then the other. So if you want a pretty package and a couple stickers for your tool box fine, but to cooralate good design and strenght directly to cost to the consumer is irrational. Sometimes simple things are better and cost less.
My motor has a stock LS1 crank in a LS2 block. But the LS2 crank is NOT forged. As far as proof. I'll let you know the next time I'll be at the track.
I do not have a clue as to the meaning of your first sentence. The gun was referenced to a gamble only. If you read first, it states that I did not post my opinion for sarcasm or scorn. I am done with this one, the meaning is 50 miles away by now. In closing notes the FAST intake is paterned after the stock GM design. Only Better. I LOVE GM stuff, however there is always a was to make it better, faster, and stronger just like the bionic man. Many racers piggy back OEM design to achieve better performance.
In closing I visit this forum almost everyday, sometimes more hours than I care to admit.
Alot of members here have been my motivation to build my car. In no way do I or did I intend to offend anyone here on this site, information is knowledge and that is what I get out of LS1TECH.COM, so keep the threads coming.. Peace...
LS1Tech Sponsor
GM MLS gaskets work very good.They are on all of our 346/408ci cars.Many 12+lb of boost up to 18psi DD cars. As for cranks,the stock one works good to 900+rwhp as proven many,many times.
