Torque Specs
Torque Specs
Is there a post on torqe specs anywhere?
Here's what I need:
Flywheel bolts -
Header Bolts -
Engine Mounts -
Pressure Plate -
Anything else I should really make sure it torqued right while putting the engine in.
Thanks!
Mike
Here's what I need:
Flywheel bolts -
Header Bolts -
Engine Mounts -
Pressure Plate -
Thanks!
Mike
That's what she said...
http://installuniversity.com/install...sity/index.htm
Click install doc'c, then clutch install.
Header bolts should be done from the inside out at 11 ft/lbs, then a second pass in the same order to 18 ft/lbs.
http://ls1howto.com/index.php?category=1
Lots of specs on there.
