Made 505 SAE at 10psi through the th400
Managed to put down 505 rwhp and 479 tq at 10 psi 91 octane. Thought that was pretty decent. The uncorrected hp was like 465. I'm running the car at the track tonight so we'll see what it does. Should be able to make 10 or so passes. Hopefully the track will be hooking and I'll be able to launch hard off the trans brake. I'm hoping the car traps in the high 120's. One of my goals for this car was to trap at least 130 on 91 octane.
If the track is really sticky i'll get to try a 4000 rpm 5psi launch
you have to look at the uncorrected numbers, thats the power the car is really making at thet elevation/temp. If the DA at the track was the same as the dyno you are looking at 465 rwhp.
465rwhp will get you ~124mph in a 3600lb raceweight car.
515rwhp will get you ~128mph @ 3600lbs.
After you run the car and correct your ET/mph to sea level then the corrected dynojet rwhp will be close.
