Things to be aware of?
I'm looking at getting a '95 to '97 Z-28 or Trans Am; I know most problems will probably have been taken care of, but other than the usual used car things to look for is there anything specific to these cars that I should be looking for?
check the door hinge area for cracks in the door. had 2 of these damn things do it. one on each side of different cars. also open the trunk and check about halfway up for stress cracks from being closed 14million times. of course the typical oil leaks and water pump problems. one thing i always look at is underneath the front of the car. look at the crossmember under the motor. see if it has been bottomed out hard enough to do damage. happy hunting!!
get under the car and check the gaskets, ie the tranny and rear gears. check oil and make sure you dont smell gas and its not burnt, check your tranny fluid for a burnt smell. check also underneath and up front by the radiator for salt damage...from the beach or snow or whatever...
one thing i didnt look at when i picked up my 99 T/A was the door panels...there were cracks in each of them and now they have spread since then looking real damn ugly...everything else on it checked out fine...but if its cosmetics your worried about then good luck finding your ride...
