Problems with my M/T's
I just finished putting my M/T 325/50/15 drag radials and skinnies on and my e-brake light and my abs inop light will not go off. Has anyone else had this problem and what can I do to fix it?
Mine come on also. I ran my Predator and it was showing an unknown error code. I haven't had any problems so far though. By the way, how did you fit 315 M/T's on the back? I was going to run those but I was afraid they would be too big.
Where under the dash is the e-brake light switch and what do I need to do? With the 325's a got a set of adj lca's and an adj lower panhardrod to help out. I had to remove the bumpstops and take a rubber mallet to the inner fenders.
