P0430- Catalyst Efficiency Below Threshold
1 Post
P0430- Catalyst Efficiency Below Threshold (bank 2)
pulled the code from my car
is my open cut out tainting my o2's? i didnt think so because its far back (under the back seat)
Naw, I run mine open most of the time at the same location. I think your passenger cat is just toast. You can swap the rear 02's and see if the code changes, but it's most likely the cat.
Swap sensors... if you pop a P0420 then it's the sensor (code followed sensor)... if it still stays P0430 then it's likely a failing cat.... a bad cat can cause performance loss (if it's clogged)
1 Post
