LS2 Timing Chain question...
I'm in the middle of a H/C swap and will be installing a LS2 timing chain and gears sometime tomorrow. Got to looking at the cam gear for the set today and noticed that there isn't a timing "dot" on the gear like the LS1 factory gears have. I did notice that there is a "U" shaped marking on the gear however.
So is this "U" shaped marking the LS2 version of the "dot" found on LS1 cam gears? The crank gear has a dot, but the only marking I found on the cam gear was this "U" shape.
Any suggestions/input?
Thanks.
Thanks.
