LS2 Timing Chain question...
Old May 18, 2006 | 02:33 PM
marv's Avatar
Default LS2 Timing Chain question...
I'm in the middle of a H/C swap and will be installing a LS2 timing chain and gears sometime tomorrow. Got to looking at the cam gear for the set today and noticed that there isn't a timing "dot" on the gear like the LS1 factory gears have. I did notice that there is a "U" shaped marking on the gear however.
So is this "U" shaped marking the LS2 version of the "dot" found on LS1 cam gears? The crank gear has a dot, but the only marking I found on the cam gear was this "U" shape.
Any suggestions/input?
Thanks.
Old May 18, 2006 | 02:34 PM
NassyVette's Avatar
Thats the dot.
Old May 18, 2006 | 02:35 PM
marv's Avatar
Thanks Nassy, that's the info I needed.
I'd hate to get that thing in there wrong!!
Thanks for the pic btw! Always helps to see what you're talking about.
Old May 18, 2006 | 06:27 PM
bad6as's Avatar
i take it the ls2 chain is stronder then the ls1 chain.
i guess it would make sence to swap the ls2 chain while doing a cam swap right?
just need the ls2 chain and ls2 cam gear?
Old May 18, 2006 | 07:19 PM
Dom's Avatar
Dom
Do you need to buy the timing set or just the timing chain? Does the set come with the chain?
Old May 18, 2006 | 07:41 PM
Lithium's Avatar
SSU's Drunk Typing Whore
Just the chain is fine.
Old May 18, 2006 | 07:42 PM
bad6as's Avatar
so just replace the cain with a oem ls2 pice? and it is stronger correct?
got a pn?
Old May 18, 2006 | 07:45 PM
Big Budda's Avatar
part # 12586482
Old May 18, 2006 | 07:46 PM
bad6as's Avatar
so why should i go with the ls2 chain?
Old May 18, 2006 | 07:50 PM
Phoenix 5.7's Avatar
the ls2 chain is much stronger.
i think u can guess which one is which
Old May 18, 2006 | 07:52 PM
TheBlurLS1's Avatar
That's what she said...
The side links are thicker, it's quite a bit stronger than the LS1 chain. When you get the LS1 chain out, you'll laugh.
Old May 18, 2006 | 09:04 PM
bad6as's Avatar
no other mods direct replacement
Old May 18, 2006 | 09:20 PM
dschmittie1's Avatar
direct replacement. I put one in my car and just put one tonight in my buddies car doing his cam swap
Old May 18, 2006 | 09:23 PM
LS144's Avatar
good idea to ask before you fire it up uncertain like I did! Or you would have this problem
Old May 19, 2006 | 06:21 PM
bad6as's Avatar
wft happened?
