cylinder balance test, what does mean,,
Old 05-18-2006, 11:29 PM
zrater's Avatar
Default cylinder balance test, what does mean,,
what does this mean , whats good # on a stock o2 z i think mine were
around 70 and 80 . thanks
Old 05-19-2006, 09:44 AM
Runn's Avatar
All mine are like 94-97...
Old 05-19-2006, 11:34 AM
zrater's Avatar
anyone , just wondering what the # means thanks
Old 05-19-2006, 12:26 PM
Runn's Avatar
Cylinder Balance: The cylinder balance test calculates % of efficiency using current RPM. RPM is gauged with all injectors running normally. Injectors are then cut 1 cylinder at a time and the new RPM is compared to the pre-test RPM to determine % of efficiency.
Old 05-19-2006, 07:03 PM
zrater's Avatar
can you tell how good the rings and piston seal or what cyl is better than the other...
Old 05-21-2006, 12:29 AM
txhorns281's Avatar
you can't tell how "good" the seal is, compression/leakdown tests would be much better for this, but you can certainly find out which cylinder could potentially be problematic
more info: http://www.hptuners.com/forum/showth...linder+balance
Test on my vehicle:
Old 05-21-2006, 07:25 PM
GuitsBoy's Avatar
Yes, run it a few times and youll see just how inacccurate this test is. Its good for diagnosing a problematic cylinder, but not so much for telling the health of your motor...
Quick Reply: cylinder balance test, what does mean,,
