Oil gurus
Oil gurus
Okay, this oil thing is beat up pretty bad here but, i'm gonna ask anyway.
German oil:
(1) Is it bad to put heavier motor oil in our camaros?
(2) I know there is no guarantee but, will the ticking noise be reduced slightly?
(3) Do they offer 5W or 10W instead of 0W?
(4) Will it change in any way i.e startups, more smoother ride or will it turn black right away?
If i remember anymore questions, i will fire them right away.
Thanks.
German oil:
Thanks.
German oil:
Thanks.
German oil:
Thanks.
2. No one can answer that honestly. No one has YOUR car and cannot diagnose a problem you are having without a LOT more information and without hearing your car. Sorry.
3. They do but it's not the german stuff. Keep in mind the first number is only when the engine is cold. The 0w just gives you more protection when starting your car in very cold climates. Even in winter once you car warms up it is the higher number 5w-30 that matters.
4. No it should not do any of those things unless it does it now. An oil is not a magic wand that can fix all your current engine troubles. It may make some better it may make your ticking go away but it may not if something other then running too thin an oil is to blame.
My 95Z is only driven in summer months. Would it be okay to put 0W in it? I spoke to the guy at the parts store and he said "I wouldn't put anything other then 10w 30"
Oh and also keep in mind that my car is an LS1. You have a completly different engine so your ticking may not be the same issue that the GC fixed for me. You have an LT1 engine but I'm betting you knew that. Either way the GC will work fine in your car. Whether it helps your problem who knows but it can't hurt to try other than it costs more than other oil. I paid about 5.50 per quart.
