meziere water pump
Old 05-20-2006, 06:39 PM
Blank's Avatar
Default meziere water pump
Where 's the thermostat located on the meziere electric water pump and is it the same kind that goes in a stock ls1?
Old 05-20-2006, 06:47 PM
That's what she said...
TheBlurLS1's Avatar
Yes I believe so.
http://www.texas-speed.com/shop/imag...p?file=mez.jpg
Edit - I was wrong, it seems that it uses a SBC style thermostat.
Here's a full writeup.
http://www.ls1howto.com/index.php?article=26
Old 05-20-2006, 08:22 PM
LS1-450's Avatar
As corrected above, it uses a SBC thermostat. Drill two small holes in the flange, 180 degrees apart & install it in the top of the pump. The holes are to allow air to escape. Stock location for the stat is in the lower water neck. On the Mezier, mount the t stat in the upper neck (return from radiator). This allows air to escape @ the highest point possible.
Also, do not remove the in-line fuse. Meziere won't warantee the pump if the fused protection has been removed.
