squeaky noise
Its been squeeaking for about 2 weeks now and last tuesday, my belt broke. I put a new one on there and it still squeaking. Had a few people tell me belt tensioner, these hard to change? expensive?
That's what she said...
The a/c system has it's own smaller belt with its own idler and tensioner pulley. You can crank the car up, make sure it's doing it, then kill the car, remove the main belt, and see if it stops.
If it stops, you know its the main.
If it keeps doing it, you can remove the a/c belt and repeat. You may also want to run over your idler pulley bolts with a wrench to make sure they are tight. My main belt idler pulley started SCREAMING on the dyno at HPE while getting tuned.
If I was getting a new tensioner, I'd get the Katech one.
https://ls1tech.com/forums/generation-iii-external-engine/501358-introducing-katech-s-new-design-billet-belt-tensioner-now-pulley-same-price.html
It's very easy to change as it's only held on by 2 bolts through the waterpump.
https://ls1tech.com/forums/showthrea...highlight=belt
