squeaky noise
Old May 21, 2006 | 12:30 AM
gccasper04's Avatar
Default squeaky noise
what would cause a squeaky noise between 500-1500 RPM??
Old May 21, 2006 | 02:01 AM
TheBlurLS1's Avatar
That's what she said...
Belt related?
You could remove your main belt and run the car, you could also remove the A/C belt to try and isolate the problem.
Since you have an UD pulley, you may need a new tensioner to stop it from happening.
Old May 21, 2006 | 06:17 PM
gccasper04's Avatar
Its been squeeaking for about 2 weeks now and last tuesday, my belt broke. I put a new one on there and it still squeaking. Had a few people tell me belt tensioner, these hard to change? expensive?
Old May 21, 2006 | 06:19 PM
Chris Gage's Avatar
They are easy to change but cost about $85 from GM..... you need to find out if it is on your main drive belt or ACC drive.
Old May 21, 2006 | 08:01 PM
gccasper04's Avatar
any tips on how to do that?
Old May 21, 2006 | 09:08 PM
TheBlurLS1's Avatar
The a/c system has it's own smaller belt with its own idler and tensioner pulley. You can crank the car up, make sure it's doing it, then kill the car, remove the main belt, and see if it stops.
If it stops, you know its the main.
If it keeps doing it, you can remove the a/c belt and repeat. You may also want to run over your idler pulley bolts with a wrench to make sure they are tight. My main belt idler pulley started SCREAMING on the dyno at HPE while getting tuned.
If I was getting a new tensioner, I'd get the Katech one.
https://ls1tech.com/forums/generation-iii-external-engine/501358-introducing-katech-s-new-design-billet-belt-tensioner-now-pulley-same-price.html
It's very easy to change as it's only held on by 2 bolts through the waterpump.
https://ls1tech.com/forums/showthrea...highlight=belt
Old May 22, 2006 | 01:57 PM
Iron Sights's Avatar
Heh, mine did the same thing on the dyno. It sounded like Unit's car. Perhaps I'll get a new tensioner afterall.
Old May 22, 2006 | 02:25 PM
Chris Gage's Avatar
I have plenty of tensioner's if anyone needs them!!!
