Is this all I need for a th350 to work on my Lt1?
Old 05-21-2006, 10:16 PM
94 z28 A4's Avatar
Default Is this all I need for a th350 to work on my Lt1?
I am going to do a th350 swap and I need to know
if this is all the stuff i need to do the swap?
The transmission comes with the following:
high quality bands, frictions and seals,
bushings,thrust washers, seals,gaskets,performance
separator plate, manual downshift valvebody.
What else will i need besides torque converter,crossmember,
and pro stick shifter? Or is that all? Also when it says
no provision for kickdown or tv cable what does that mean?
Thanks
Old 05-22-2006, 01:45 AM
revtime's Avatar
As long as its a 9 inch tail shaft TH350 you can reuse the stock DS.
Your going to need to figure out how to get the speedo working.
I have a Rossler TH400 and he installed a VSS out of a early 90s 454 SS pickup so it was simply plug and play for me.
I have the dakota digital speedo converter sitting out in the garage if you need one, I bought it thinking I would need it and the tranny I ended up buying already had the VSS conversion.
A good transmission cooler is a very good idea especially if your going to run a high stall converter.
no provisions for TV cable or kickdown usually means its a manual valve body which means you have to shift it yourself all the time.....upshifts and downshifts.
Old 05-25-2006, 08:48 PM
94 TA TT2S's Avatar
Rev time whats involved in that Dakota digital box......and what are you asking for it.....Will it work with TH350???
Old 05-25-2006, 10:18 PM
revtime's Avatar
Its part number SEN-01-1 and you splice your VSS wires to it.
Take a look at Dakotas website and you will get a good idea how it works.
20 bucks shipped.
Its brand new never been used.
My TH400 has a VSS and reluctor ring from a 90s 454 SS pickup installed, all I had to do was take the VSS wire and plug it in.
