They DO exist!! (MSD Opti)
my mouth just watered a little when I saw the picture, what else do you have to run to use that MSD opti, thats the pro billet version right? I noticed the connector is different for the cam position sensor, how did you hook it up?
Originally Posted by luckyou03
i dont see the big deal?? you never see the opti when installed, and the gm one works fine. it's like chrome plating my horn
Originally Posted by harvickgm
the factory opti is a piece of ****, hopefully this will be the end of the opti problems... i guess only testing will reveal the answer...
A factory unvented one may be, but a vented version is a whole lot better. While the rotor may not like high RPMS, when you maintain an opti as you are supposed to do with a traditional cap and rotor distributor they last a long time. Believe me it's nothing compared to a coil pack setup, but they do work.
Now Ponyhntr, I hope they provided you with a new vacuum harness or at least say you should change your old one out for a new one. Believe me for $20 it's cheap insurance to ensure you're not going to **** up a $500 product
