Magnacharged C6 Vette Track Results
I finally made a visit to HRP tonight to try out the new setup on the 2005 Corvette, consisting of a Magnacharger at 5 psi boost, 230/230 114 cam, and LG longtube headers with a Magnaflow catback. The car is a Z51 coupe, 6-speed manual. Raceweight was 3500 lbs even, temps 88F outside. The car was on 17" drag radials. Granny shifting to keep the rearend in one piece.
Best ET was 11.37 @ 126.7 with a 1.84 60'
Best MPH was 11.47 @ 129.5 with a 1.95 70'
The higher MPH pass was done after letting the car cool down for an hour. The best ET pass was just a better launch. Too bad I couldn't get the combo on the same pass. The car ran 103 mph in the 1/8-mile on the 11.47 pass. Ran two more hot laps and didn't improve any.
I didn't manage to escape the track without breaking something though. Put a nice hairline crack about 6 inches long on the back of my differential housing, causing some pretty bad oil leakage. I managed to drive the car home 25 miles though, and will diagnose any further damage tomorrow. Hopefully its just the housing and nothing else.
But hey, thats racing! Had a great time anyways.
Tony
Tony
Nice times sorry to here about the diff though. I dont know if you've seen the latest motortrend with the LPE twin'd C6 vette. But it literally left half the differential at the starting line....
1 Post
Get the DTE Brace if and when you get the new rearend. That will absorb a lot of the stress that high torque motors like yours places on the casing/housing of the trans and diff. when you shift hard at high rpms. For 400.00 you can save several grand. Good luck. Hope it works out for ya. I got the brace, and have had no issues as of yet.
Tony
Tony
how much power were you making with 5psi?
~550 rwhp
bummer about the diff..
little fyi. install a small 30-35 dry n20 shot with the maggy, it really helps with the cooling effects.
i was consistently getting 11.02-11.09's at 121-123. consistent.
installed 30shot (2x .020jets) and my iats dropped tremendously. it countered the heat and humidity here in tx. now running mid to hi 10's, consistent.
best to date has been 1/8th 6.81 at 101.8, 1/4 10.66 at 128.51. 1.55 60ft.
my ride does produce some decent short times average 1.50-1.60. 17in mt et drs, rpm a4, yank 2800st.
just fyi, FWIW good luck on the repairs
