Able to pass the sniffer with racing longtubes
Old 05-25-2006, 05:27 PM
Cchris1109's Avatar
Default Able to pass the sniffer with racing longtubes
is it possible to pass the sniffer when i go to emissions, i have the racing long tubes, they wont know that it has air or egr because my diagram is blocked by the ram air...it has cats and all, just curious if people have passed before or should i be like yes i need this to pass *slip a 20* ha
Old 05-25-2006, 07:51 PM
95_Firehawk_Dude's Avatar
Seems like you should be able to pass... whats the tune like?
I'm sure AZ emissions are differant from IL though
Old 05-25-2006, 09:27 PM
Fastbird93's Avatar
I don't follow what you say here. It's going to be obvious that you're missing the AIR/EGR Equipment when the tech pops the hood. Not to mention the relocation of factory cats causing an instant failure if they notice.
But the roller........if you have cats on the car, you shouldn't have any issues passing the sniffer.
I used to live in Scottsdale, AZ emissions were almost as bad as CA emissions to get through.
Old 05-25-2006, 09:43 PM
Cchris1109's Avatar
tune is madz28 tune, its not that obvious that its missing AIR/EGR if the tech doesnt see the diagram
Old 05-25-2006, 10:17 PM
They pop the hood in AZ
Old 05-29-2006, 10:53 AM
Sick99WS6's Avatar
That sucks they pop the hood. Do they actually know what to look for?
I passed the sniffer with the Z before I had the CC306 go in with FLP longtubes with the cats on.
Old 05-29-2006, 11:09 AM
Nite_Hawk's Avatar
in AZ it's like putting your car on a dyno...I took an older car, with no 02 sensor, missing muffler and running like poop and it passed big time. You should have no worries.
Old 05-30-2006, 09:31 AM
thelostartof's Avatar
in AZ they just do the tail pipe test and make sure your fuel system return works .. easy crap
my brick passed with a giant IC in there, cone and big exhaust (EGR still hooked up tho). and about 30% larger injectors with a stock ECU
as long as the tune is setup right it will pass
Old 05-30-2006, 10:09 AM
lastcall190's Avatar
I passed NJ emissions with LTs and cats... my NOX reading was ONE point away from failing. I was surprised myself. Not sure how bad AZ emissions are, good luck.
-J
Old 06-04-2006, 05:54 PM
Cchris1109's Avatar
NJ should be more strict because of the pollution there, i put em on and im going to try and fab an air tube so i can pass the visual.
Thanks, and the car runs great with em on!
Old 06-04-2006, 07:47 PM
infinitebird's Avatar
I don't think you will pass with LTs if there is a visual due to cat relocation.
Quick Reply: Able to pass the sniffer with racing longtubes
