Throttle Position Output Wire?
Old 05-27-2006, 06:18 PM
ZoFastSS's Avatar
Default Throttle Position Output Wire?
I have been searching the archives, and was able to find alot of Info. on the Throttle Position Sensor, but am unsure on my 98, if the output wire is the blue one. I'm hooking up a Zex Kit and do not want to splice into a wrong wire. Help on this would be appreaciated.
Old 05-27-2006, 07:26 PM
2xLS1's Avatar
Blue is the TPS variable output.
Old 05-27-2006, 07:34 PM
1LoudTA's Avatar
check it with a volt meter just to make sure, make sure the voltage is around .60v with the throttle closed then turn it by hand and make sure the voltage flucuates properly.
Old 05-27-2006, 07:40 PM
qwiktim's Avatar
+1 on the blue wire.........
Old 05-28-2006, 12:12 AM
ZoFastSS's Avatar
Wink
Yep, checked with the voltmeter, its the blue wire. Thanx for the help.
Quick Reply: Throttle Position Output Wire?
