How do gears affect dyno numbers?
Old 05-28-2006, 09:34 AM
Marc '99T/A's Avatar
LS1Tech 10 Year
Default How do gears affect dyno numbers?
From what I understand, the higher the rear end gear ratio, the lower the #'s will be on the dyno. Is this correct, and can anyone explain why it is so? Thanks,
-Marc
Old 05-30-2006, 09:29 PM
LS1Tech 10 Year
Uhhh...........anyone???
Old 05-31-2006, 01:30 AM
BirdofPreyBandit's Avatar
I always heard that gears do not affect dyno numbers. I don't understand how that can be but I've always been told that. Can anyone shed some light on this?
Old 05-31-2006, 01:33 AM
ninetres's Avatar
In general.......I have heard that they don't effect dyno numbers. Then the same experienced people who told me this have later said,"Wellllllllllll tehy do, but only a little bit. Like maybe 10whp less reading when switching from 3.42s to 4.10s."
Whoknows.
Old 05-31-2006, 02:06 AM
Cool Z's Avatar
It's my understanding that the HP numbers will read slightly less, but the torque will be higher. Auto cars with a higher stall tend to lose a few ponies to the rear wheels, but the torque increases due to the torque multiplication produced by the higher stall. So in essence, it would make sense that a higher numerical gear ratio increases torque multiplication to the rear wheels. As far as the a slight HP loss, I do not know the technical answer. A friend with a 2002 Z28 went from 3.42 to 3.73. He gained 10 RWTQ and lost like 3 RWHP on average.
Old 05-31-2006, 07:34 AM
01RedT/A's Avatar
your gears (or final drive ratio) should be figured into before you do your run. if i remember right, the operator should input that into the dyno. overall though, if you dont factor in the ratio, the higher the ratio, the more torque you should read, since the mechanical advantage is "higher". anyone know for sure?
Old 05-31-2006, 07:57 AM
Grimes's Avatar
In terms of drivetrain loss, it will affect the numbers only a tiny bit.
A dyno dosen't care what is spinning the rollers, so a dyno will spit out hp numbers no matter what car (or gear ratio) is turning it.
Old 05-31-2006, 08:20 AM
CHRISPY's Avatar
There is parasitic loss running a deeper (numerically higher) gear ratio. Typically you'll see 8-10RWHP loss going from 3.42 to 4.10 in a 10 bolt. With a swap from a 10 bolt with 3.42s to a 12 bolt with 4.10s and heavy DS you'll see slightly more.
9 inch rears are the worst due to offset pinion location. 9 inch rears are the strongest though.
To help offset the loss you can run gun drilled axles, alum gears etc. Most just live with the slight loss for greatly increased strength.
Old 05-31-2006, 06:45 PM
Moderator
davered00ss's Avatar
Yes, you do lose HP with gears.
Old 05-31-2006, 06:54 PM
Denom's Avatar
I believe you lose horsepower to the wheels, but not to the engine with a gear swap.
I may have my car dynoed again to see what horsepower loss I have since I had the 4.10's put in.
Old 05-31-2006, 09:59 PM
LS1Tech 10 Year
So overall, you do, lose some but it could be minor. Then again, it could be inputed into the computer when the dyno is set up, resulting in a more corrected number. Uhhh...right?
Old 05-31-2006, 10:54 PM
Denom's Avatar
I wouldn't think of it that way. I'd say think of a 10 speed bicycle. You go to a lower gear (Or taller gear if you would), so that you can get up the hill a little easier, although at a slower pace. That would be my view on it. Basically anything over your 3.23/3.42 gearing is a taller gear. You can get outta the hole alot easier, but you suffer in the top end.
Old 06-01-2006, 02:20 AM
ninetres's Avatar
Like top speed top end.....not the 1/4 mile top end from my ecperience. Pulls harder all the way through the traps (3.42---> 4.10 swap)
Old 06-02-2006, 03:16 PM
I think you'll only lose top speed not top end in the 1/4. I'm trapping 117 mph and before the 4.11's, I was trapping about 115 mph.
Quick Reply: How do gears affect dyno numbers?
