Clutch
Yes it will fit, however it might not engage and disengage like you want it to.
The Vette has a dual mass flywheel, the f-body does not. The Vette clutch disk DOES NOT have the dampening springs built in, the F-body disk does.
That is the difference.
The vette does have a better throw out bearing which works well in the f-bodies.
You are better off getting the f-body clutch to avoid possible bigtime chattering issues.
well an M6 would do that for you, since our cars are externally balanced. youll want a flywheel thats designed for the LT1 SLP, Fidanza, SPEC, all offer flywheels that are ready to bolt on but to be sure you might go ahead and have them checked by a machine shop to check and make sure correct, my SPEC flywheel was...
