need info on what cam to get..
Well im planning to purchase a cam for the lt1 but what cam would be best for me? I use the the lt1 as a dd but i go to the track too so i want best for both worlds.Any suggestions would be appreciated.
same here looking for a good mod and everyone says to get a cam....how big for a dd and how much will it cost if i have a shop install? what gains can i expect? i think i saw a guy on here who went from likr 315-900 lbs of torque or rwh im not sure if that is correct though......
krayzie7th...Need more info. What bolt ons do you have? M6 or A4? How much power do you want to make? Doing it right requires a lot of supporting mods for a cam.
laxmad16, Uhh 315-900lbs of tourqe would require a pretty unstreetable setup and from a cam only car it's not even likely. Perhaps it was a typo? You are going to need a set of headers for a cam just for starters.
CCA-07-466-8
Brand: comp cams
Product Line: Competition Cams Xtreme Fuel Injected Camshafts
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 1,800-5,800 RPM
Intake Duration at 050 inch Lift: 218
Exhaust Duration at 050 inch Lift: 224
Duration at 050 inch Lift: 218 int./224 exh.
Advertised Intake Duration: 268
Advertised Exhaust Duration: 276
Advertised Duration: 268 int./276 exh.
Intake Valve Lift with 1.6 Rocker Arm Ratio: 0.570 in.
Exhaust Valve Lift with 1.6 Rocker Arm Ratio: 0.565 in.
Valve Lift with Factory 1.6 Rocker Arm Ratio: 0.570 int./0.565 exh. lift
Lobe Separation (degrees): 113
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Computer Controlled Compatible: Yes
Grind Number: 268XFI HR13
also needs:
2800 stall
52mm TB
1.6 rockers
comp 918 spring
Brand: comp cams
also needs:
2800 stall
52mm TB
1.6 rockers
comp 918 spring
Take a look at the LT4 Hotcam Kit. It's a little on the older side technology wise but it will make over 300rwhp and comes with everything you'll need. Real good bang for the buck and popular amongst LT1 guys.
CCA-07-466-8 $245
Comp Pro-Mag 1.6 Rockers $325
918 Spring $180
Yes what I suggest is more $$$ but it is also better components.
Always remeber you get what you pay for.
how much better is the:
CCA-07-466-8
Brand: comp cams
Then the Lt4 cam around how much more hp would i get?
CCA-07-466-8
Brand: comp cams
the XFI grinds are specificlly designed for fuel injected cars....you should see 20-30hp gain over the hot cam.
The cam price is about the same.
The Pro-mags are one of the best 1.6 rockers on the market...there are some you can buy for approx $170.
The 918 springs are Comps new Beehive spring...they will hold up to the larger lift numbers.
The rockers in the hotcam kit are GMPP..not designed for heavy duty applications IMHO..also the springs will not support much more lift if you ever decide to go bigger.
Which you will if you go with the hotcam.
I just took out my 222/228 .544/.538 112 because it was not enough cam for my goal.
I am now running 246/254 .613/.590 112
