Help with A/F Gauge
The A/F gauge all you need in a 12v, ground, and the other wire goes and taps into the white wire on one of the O2 sensors , ( I will se if I can find the # and place I bought an adaptor which plugs into the 02 and has a pig tail which you may connect on to without having to cut into any wires, if I find it I will getback to you ) good luck Johnny
There are letters on the plus of your o2's. My 01 TA had the factory 02's and it used the purple wire(letter B on the pigtail). When i got my aftermarket ones it had 2 whire wires so just go by the letters on the pigtail unless you just gotta do it on the computer. I didnt because i didnt wanna cut the factory wires so i cut the wire on the sensor.
