running AC and a cam??
i've had a TQ 2 cam from TSP for a while now, i was just trying to find out, what i need to do to be able to use the car's AC? i dont have a tune yet, but what exactly in the tune do i adjust for AC? and is there anything eles i can do, what do you guys out there with cammed up cars do with the AC? i already dont use the AC it just for the few times that i do.i can only use it when im on the highway, not stop and go traffic or the car will die. any info would help?
i run the magic stick and I have no problems with running my ac. The only time it has a problem is when I start the car and I forgot to turn the ac off, it has a little trouble tryin to find idle, but I just turn it off.
You have to bump up the max idle air offset. Its an idle trim that automatically measures how much extra air is required when you have the a/c on. Stock, its limited to .50 g/s. I bumped mine up to 2.0 and havnt once it learned itself out, i havnt had any trouble. Make sure youve got your RAF inline first.
