LT1 TH350 crossmember PICS
Old 06-01-2006, 06:03 PM
foggedz's Avatar
Default LT1 TH350 crossmember PICS
I thought I would post some pictures of how to modify a stock auto LT1 crossmember to work with a TH350 trans. The TH350 trans mount is just slightly closer to the motor than the 4l60e. All you have to do is weld a tab, and some little arms off the side to support it on to the front of the crossmember. Then drill out a new hole for the mount. If I remember correctly the new hole should be about 1in in front of the old hole.
Old 06-01-2006, 06:07 PM
Dragframe's Avatar
very very nice.. looks great.... maybe i should rethink getting a new one...
What are you doing about the torque arm...
Camaro Bird 1987's Avatar
are the K-members the same way with a v6 Manual trans?....yeah I know that I am hoping.... a lot...
Old 06-01-2006, 06:10 PM
Dragframe's Avatar
um i would put big money on them not being... the lt1 manual trans k-member is different...
Old 06-01-2006, 06:41 PM
foggedz's Avatar
I use a spohn torque are that mounts to the gload brace area.
Old 06-01-2006, 09:25 PM
Shon Herron's Avatar
that is what I did on mine too.
Old 06-02-2006, 10:38 AM
Vaders94's Avatar
looks like the one i have, good job
Old 06-02-2006, 12:43 PM
dhdenney's Avatar
UMI makes a very affordable tunnel mount TQ arm.
Quick Reply: LT1 TH350 crossmember PICS
