700 rwhp with procharger possible ??
Old 06-01-2006, 10:24 PM
blue2002ss06's Avatar
Default 700 rwhp with procharger possible ??
Is 700 rwhp possible with the D1SC 8 ribbed kit?? I have the kit with 60 lb injectors,fuel pump,SCDE tensioner and a forged 346 comming up. How many pounds of boost can I run to obtain this goal, if it is possible??? Also how much strain will it be on this motor???
Old 06-01-2006, 10:37 PM
TS6
TS6's Avatar
Yes, it is. Shouldn't be too hard, boost will depend on combo though.
Old 06-02-2006, 01:29 AM
BIG BAD BLACKSS's Avatar
Would it be easier with more cubes, or will the D1SC run out of steam and make less power on a big cube motor like a 370 or 408?
Old 06-02-2006, 04:09 AM
EPP
EPP's Avatar
Smile
http://www.exoticperformanceplus.com...Car.php?car=27
Check out the link above, where we got 717 rwhp at just 5200 rpm with a 346 ci and an ATI ProCharger D-1SC. 16 psi of boost combined with the Lingenfelter GT2-3 camshaft, and Patriot LQ9 Stage 3 heads.
Since the engine doesn't have to be taken in orbit in rpm, it should last for a long time. Bob
Old 06-02-2006, 04:13 AM
EPP
EPP's Avatar
Smile
You could do it easier with a 382, and not run the blower out of breath. A 408 would indeed run the D-1SC out of steam much sooner, but you still would more than likely see 700 rwhp. Bob
Old 06-02-2006, 05:34 AM
2001WS6Vert's Avatar
I doubt you can get all the way to 700 rwhp since your an automatic.
Old 06-02-2006, 03:54 PM
Oh4GTO's Avatar
Are there any bad sideffects to stroking stock cubes when going blown?
Old 06-02-2006, 04:04 PM
rjkZ28's Avatar
i dont understand why you wouldnt be able to make that power? if im not mistaken on Prochargers website said the supercharger is good to 32PSI i believe. and the next supercharger after that would be the F1 series.
Old 06-02-2006, 04:27 PM
7 Second Club
ty_ty13's Avatar
PSI has nothing to do with horsepower... it only shows the motors restriction...
when looking at a blower find the CFM that it will flow or do the generic thing and look at how much HP it will support and take about 8-10% off
Old 06-02-2006, 04:53 PM
LS1Tech Sponsor
Slowhawk's Avatar
Compression and Head/Cam choice will dictate the power you make.You will need more fuel system for 700rwhp than what you got.
As for power, we've made 820+rwhp with a D1 and A3 but it had some good compression
Old 06-02-2006, 05:10 PM
SSilverSSurfer's Avatar
on a forged motor it should make that no problem especially with the D1 kit
Old 06-02-2006, 05:37 PM
Mr Powell's Avatar
MTI made 711rwhp today on a stock bottem end, stock cammed, stock heads, stock catback C6. No Meth at all.
Old 06-02-2006, 05:42 PM
1LoudTA's Avatar
that wont last long
Old 06-02-2006, 05:58 PM
Mr Powell's Avatar
I bet it will..
I mean Chris from MTI has made almost 700rwhp and 800+rwtq for right at about a year on a stock LS2 bottem end on nitrous.. and it goes through a bottle a week.
The Vette should easy do well into the 140s in the 1/4 when we goto the track in a week or two.
Old 06-03-2006, 07:15 AM
Chicago Crew UnderBoss's Avatar
I agree, with proper tuning and nice little blower cam it should be a no brainer but you will most likely have to upgrade your fuel system also to support those horsepower levels!!
Old 06-03-2006, 12:45 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,103 Likes on 723 Posts
I've hit 754rwhp with a forged 348ci, Vortech YSi, front mount, race gas, and a very conservative tune. If I bothered to spend more time on the belt system I maybe could have hit 775rhwp or even 800rwhp like with cogs.
I'm sure a D1 can get to 700rwhp if you have the fuel system and can keep the blower belt on.
Old 06-03-2006, 02:12 PM
Wicked_Hugger99's Avatar
Speed Inc hit 725rwhp on my old vortech YSI setup @13psi on 104oct but pullied it back down to 641rwhp@10psi on pump gas w/ a forged 348ci motor back in the Summer of 2004 so i'd say you making 700+rwhp w/ a D1 on a decent combo/tune should be fairly easy
Old 06-03-2006, 02:20 PM
7 Second Club
BlwnTA's Avatar
See sig....close without NOS, my heads are ported LS1's. Good set of heads and you should get pretty close. You won't see the same torque unless you go bigger cubes.
Quick Reply: 700 rwhp with procharger possible ??
