7 Heat Range Plug???
Does anyone know of a spark plug in the 7 heat range designed for the ls1, actually c5r heads, motors. Tr55 ngk has a 14mm thread size, is tapered, 5/8" wrench diameter, and .708" reach so these are the specs i'm looking for. Thanks.
P.S. It's for my 434" c5r headed 11.5 to 1 darton sleeved ls1. Projected n/a hp is around 700 fly wheel, thanks.
Originally Posted by Mike@TEA
ngk lists a # BP7EFS OR STOCK #3526 it appears the tip is not extended as far as the tr55-tr6. that also crosses to an autolite 103.
Originally Posted by Beast96Z
If your going N/A, why are you looking in the 7 heat range? I planned on 6's in my 11:8:1 N/A 454. 7's are for big No2 app's.
