New Supercharger! now 1 question
Old 06-03-2006, 04:08 PM
Red97Z's Avatar
Default New Supercharger! now 1 question
Ok, my supercharger kit came, but its missing some components. As for the pressure relief valve, where does the air discharge tube go? It's a large opening 1" x 2 1/2", am I supposed to run a hose from the opening of it and direct it somewhere, can someone shed some light on this?
Old 06-03-2006, 04:16 PM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
Without the who, what, when, where, why, I don't think anybody can help you. We need specifics...
Old 06-03-2006, 04:29 PM
Red97Z's Avatar
Ok, I have a vortech s trim v1, right now I just need to know if theres a tube that the air discharge tube on the pressure relief valve hooks up to. I'l take a pic of the component in a min or post one up for reference. thanks
Old 06-03-2006, 04:32 PM
Red97Z's Avatar
I was fortunate enough to get a pressure relief valve, http://www.vortechsuperchargers.com/...tegory_Code=AC
but my question is, does the air discharge valve hook up to anything, or is it just open in the engine compartment, it doesn't seem like it would be. just need help in the right direction
Old 06-03-2006, 04:50 PM
H8Mac's Avatar
I think and air disharge valve is also known as a BLOW OFF valve, if so that is released into the engine compartment ,,, not back into the piping
Old 06-03-2006, 04:56 PM
Red97Z's Avatar
Yes, on turbo applications it's a blow off valve, basically the same exact thing. So you're saying that that air is just released into the atmosphere, no specific location in the engine compartment? I think I might run a hose so that debris doesn't get caught up in the valve.
Old 06-03-2006, 05:31 PM
I use a Vortech/Mondo BPV vented to the atmosphere. You can also put an air filter on it to quiet it down some.
Old 06-03-2006, 05:44 PM
losiguy's Avatar
On Turbo Applications its a wastegate, in supercharged applications its a blow-off valve.
Old 06-03-2006, 05:47 PM
Wrongo: On Superchargers its a Bypass valve not BLOW OFF VALVE.
Old 06-03-2006, 07:12 PM
kbracing96's Avatar
If the MAF sensor is before the blow off/ by pass, then it needs to be vented back in to the tubing before the supercharger or your venting metered air and it will throw off the pcm. That is the way the Vorteh I took off a LT1 was last weekend.
Old 06-04-2006, 12:36 AM
Red97Z's Avatar
my maf was relocated by the filter on the supercharger head unit.
Old 06-04-2006, 12:30 PM
kbracing96's Avatar
Then your bypass should be vented back into the tube feeding into the blower after the MAF and not to atmosphere.
